[gdal-dev] GDAL for BNG to Lat/Long, WGS84
scottd777 scottd777 at yahoo.com
Sun Feb 28 21:10:28 EST 2010
Hi, and thank heaven for GDAL!
I was so happy to find this tool, but I am having some trouble figuring out
the exact command I need for an image warping application.  If there is
someone who doesn't mind a newbie type question, I could really use the
help!
Essentially, I have imagery which is referenced with British National Grid.
I am tyring to convert / warp this so that it can be used within Google
Earth.  I have reference points for the upper left and lower right of the
image in Easting and Northing, and transformed those so that I got lat /
long coordinates which line up very well within Google Earth, however it
appears that the projection is off.
I am hoping to use gdalwarp to convert the TIF file (referenced as
mentioned), but I had some questions:
- For the world file that I create for gdalwarp, should I include the
Easting / Northing, or does this need to be lat / long?
- Can I just go straight to gdalwarp, or do I need to do some other
translation first?
- The command I am trying to use looks like this:
gdalwarp -s_srs "proj=utm +zone=33v +datum=OSGB36" -t_srs "proj=latlong
+datum=WGS84" filein.tif out.tif
Is this the correct command to get from a BNG source ortho image to what
would overlay correctly in something like Google Earth?
Many thanks for any help!
-Scott
View this message in context: http://n2.nabble.com/gdal-dev-GDAL-for-BNG-to-Lat-Long-WGS84-tp4652000p4652000.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
