[gdal-dev] Maintenance Report from Oct 28, 2009 to Jan 1, 2010
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Jan 1 13:51:38 EST 2010
I updated my GDAL maintenance report at
http://trac.osgeo.org/gdal/wiki/MaintenanceReportsByChaitanya
I am also attaching a copy.
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
GDAL Maintenance Reports by Chaitanya kumar CH.
Duration: Oct 28, 2009 to Jan 1, 2010
#3148: Patch to make frmts/gtiff/tifvsi.cpp compile under VC++ 9.0
#3154: Configure snippet is not truly able to manage both netcdf3 and netcdf4
#3166: can't make large/64-bit netCDF file
#2270: Patch for HDF5 block size recognition
#2948: GML read failure for GDAL 1.6+
#3213: ESRI ArcInfo ASCII driver not Mac-compatible
#3242: Northwood/VerticalMapper driver isn't big endian compatible
#2991: OGR PGeo driver's GetGeometryRef() returns NULL for lines/polygons with Z coordinates
#1918: PGEO: Missing geometry types (ie. type 9/19/29)
#3100: Type 51 of geometry in Personal Geodatabase/shape
#2842: Unable to delete colormap from HFA
#2221: OGR SQL limits table name and column name character set
#1999: Slowness of CPLReadLine() function on Windows
#1367: PGEO driver should not force MDB Tools on Unix platforms
#3259: GeoTiff driver problem with JPEG Encoded Images
#3260: like in ticket #2643 where shape type 50 PGeodatabases are not recognized, 51 seems to be the same issue
#1540: Minor memory leaks in gmlreader.cpp
#3202: BURN_VALUE_FROM option for GDALRasterizeGeometries
#2304: Failed test in ogr_mysql.py
#3247: Shapefile driver truncated field names, sometimes causing duplicates
#3237: Northwood/VerticalMapper Driver Contribution
#3161: Enhancements proposal for gdal_merge.py
#3236: Ogr2ogr stops appending to .shp file at 2 GB
#3129: Contour orientation
Compiler warnings in MS Windows
Chaitanya kumar CH
chaitanyach at gmail.com
