[gdal-dev] gdal_translate
Andrew Brooks arb at sat.dundee.ac.uk
Wed Jan 6 15:42:46 EST 2010
2010/1/6 Frank Warmerdam <warmerdam at pobox.com>:
> Greg Coats wrote:
>> image_in1.tif is a .tif without georeferencing info. image_in2.tif is a
>> .tif with georeferencing info. What do I add to the gdal_translate command
>> below so that the output image_out3.tif, whose pixels will be identical to
>> the pixels in image_in1.tif, will include the georeferencing info in
>> image_in2.tif?
> gdal_translate will not do what you want unassisted.
Isn't this what the geotifcp and applygeo programs are for?
Andrew
