[gdal-dev] from georeferenced raster to georeferenced vector
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 7 01:20:01 EST 2010
Greg,
Try the gdal_polygonize.py program from http://gdal.org/gdal_utilities.html
You may have to do some post processing on the shapefile.
On Thu, Jan 7, 2010 at 7:13 AM, Greg Coats <gregcoats at mac.com> wrote:
> I have a simple .tif, created in Photoshop, that consists of a horizontal line, a vertical line, and some text, and that (thanks to Frank) is now a georeferenced GeoTIFF. Is there a command line tool that will read in the georeferenced GeoTIFF and write out a georeferenced vector file, likely a .shp file? Greg
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
