[Gdal-dev] ECW Hanging
Fri Jan 8 02:21:33 EST 2010
srweal wrote:
> Hi,
> I'm experiencing intermittent problems running the FWTools 2.2.6 version of
> GDAL, including ECW support.
Steve,
Generally speaking, I have also had problems with the ECW support in
FWTools.  FWTools is built with a sort of custom copy of the ECW SDK
I hacked together a build for.  I think that may relate to the problem.
I would encourage you to try using OSGeo4W with the ECW plugin instead.
It uses the ECW SDK as distributed by Leica and hopefully will be more
stable.
   http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw
Also of possible interest, but unlikely related to your particular problem
is this bug I worked on just this week.
   http://trac.osgeo.org/mapserver/ticket/3245
Best regards,
