[gdal-dev] Memory use in GDALDriver::CreateCopy()
ozy sjahputera sjahputerao at gmail.com
Tue Jan 12 10:57:42 EST 2010
I was trying to make a copy of a very large NITF image (about 40Kx100K
pixels) using GDALDriver::CreateCopy(). The new file was set to have
different block-size (input was a scanline image, output is to have a
128x128 blocksize). The program keeps getting killed by the system (Linux).
I monitor the memory use of the program as it was executing CreateCopy and
the memory use was steadily increasing as the progress indicator from
CreateCopy was moving forward.
Why does CreateCopy() use so much memory? I have not perused the source code
of CreateCopy() yet, but I am guessing it employs RasterIO() to perform the
read/write?
I was trying different sizes for GDAL  cache from 64MB, 256MB, 512MB, 1GB,
and 2GB. The program got killed in all these cache sizes. In fact, my Linux
box became unresponsive when I set GDALSetCacheMax() to 64MB.
Thank you.
Ozy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100112/12de21aa/attachment.html
