[gdal-dev] Projection issue with a netcdf file
Kyle Shannon ksshannon at gmail.com
Tue Jan 12 15:38:24 EST 2010
After a little digging, it appears that the netCDF driver does not support
the tag:
Lambert_Conformal:standard_parallel
it supports:
Lambert_Conformal:standard_parallel_1
and:
Lambert_Conformal:standard_parallel_2
I am not sure if the tag is out of specification, or if the driver needs to
be updated.  I also notice OGRSpatialReference has a separate function for
setting a Lambert Conformal Conic with single parallel:
OGRErr SetLCC1SP( *double* dfCenterLat, *double* dfCenterLong, ...
but this is not referenced in the netCDF driver.
So, my next question is:
Can you specify the value of SP_1 and SP_2 as the same parallel in the
standard LCC, or do you have to set LCC1SP
Thanks everyone for your patience,
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)646-6577
kshannon at fs.fed.us
On Tue, Jan 12, 2010 at 11:26 AM, Christopher Barker
<Chris.Barker at noaa.gov>wrote:
> Kyle Shannon wrote:
>> ncdump -h reports the same correct standard parallels (25) whereas
>> Coordinate System reports 0 for both standard parallels.  It appears the
>> projection is a Lambert Conformal Conic with 2 standard parallels, but they
>> are the same effectively making it a lcc with 1 standard parallel.
> It looks like GDAL doesn't understand those parameters:
> from: http://www.gdal.org/frmt_netcdf.html:
> Georeference
> There is no universal way of storing georeferencing in netCDF files. The
> driver first tries to follow the CF-1 Convention from UNIDATA looking for
> the Metadata named "grid_mapping". If "grid_mapping" is not present, the
> driver will try to find an lat/lon grid array to set geotransform array. The
> NetCDF driver verifies that the Lat/Lon array is equally space.
> If those 2 methods fail, NetCDF driver will try to read the following
> metadata directly and set up georefenrencing.
>    * spatial_ref (Well Known Text)
> So to get the spatial reference right, the netcdf file needs a proper
> spatial_ref parameter in WKT format. What does ncdump tell you it has? If
> it's not right, you can either get whoever is running your server to fix it,
> or you can fix it yourself by processing the nc file with something:
>  ncdump-> filter -> ncgen
>  NCO utilitites
>  python (or perl, or ???) scripts.
> good luck!
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R            (206) 526-6959   voice
> 7600 Sand Point Way NE   (206) 526-6329   fax
> Seattle, WA  98115       (206) 526-6317   main reception
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100112/d1c7cee8/attachment.html
