[gdal-dev] reading VPF format NGA DNCs
Christopher Barker Chris.Barker at noaa.gov
Thu Jan 14 19:04:01 EST 2010
Christopher Barker wrote:
> Frank Warmerdam wrote:
>> For what it's worth, the connection string I use is:
>>   gltp:/vrf/home/warmerda/data/vpf/dnc13/h1316010
>> Within the h1316010 directory I have files in lower case:
>> warmerda at gdal64[105]% ls h1316010/
>> cat  dqy  env  hyd  lcr  libref  lineage.doc  obs  rel
>> cul  ecr  grt  iwy  lht  lim     nav          por  tileref
>> The driver is (I believe) case sensitive on linux/unix.
> That would explain it those are all upper-case on my machine -- I'll try
> lower-casing everything and see what I get.
no luck.
However, when I give the full path:
ogrinfo gltp:/vrf/Users/cbarker/Temp/DNC/DNC16/A1611290/
I get:
vpf_open_table: error opening </Users/cbarker/Temp/DNC/DNC16/A1611290/LAT>
which is a little better -- and indeed there is no "LAT" or "lat" in
there -- maybe I don't have a fell set? Though I just downloaded it, and
it sure looks like everything is there. Not that I"m sure what everythig
is supposed to be.
Maybe I'll try on Windows...
Thanks,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
