[gdal-dev] gdal + ace2-data
Even Rouault even.rouault at mines-paris.org
Fri Jan 15 15:48:40 EST 2010
Helmut,
 From the doc, the ACE tiles are just raw files. So this is the perfect
use case for using VRT descriptions for raw files :
http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_vrt
For example, for the 30N000E.ACE file, you can create a 30N000E.VRT
description file
<VRTDataset rasterXSize="1800" rasterYSize="1800">
  <SRS>GEOGCS[&quot;WGS
84&quot;,DATUM[&quot;WGS_1984&quot;,SPHEROID[&quot;WGS
84&quot;,6378137,298.257223563,AUTHORITY[&quot;EPSG&quot;,&quot;7030&quot;]],AUTHORITY[&quot;EPSG&quot;,&quot;6326&quot;]],PRIMEM[&quot;Greenwich&quot;,0,AUTHORITY[&quot;EPSG&quot;,&quot;8901&quot;]],UNIT[&quot;degree&quot;,0.01745329251994328,AUTHORITY[&quot;EPSG&quot;,&quot;9122&quot;]],AUTHORITY[&quot;EPSG&quot;,&quot;4326&quot;]]</SRS>
  <GeoTransform>0, 0.0083333333333333332, 0.0, 45, 0.0,
-0.0083333333333333332</GeoTransform>
  <VRTRasterBand dataType="Int16" band="1" subClass="VRTRawRasterBand">
    <SourceFilename relativetoVRT="1">30N000E.ACE</SourceFilename>
    <NoDataValue>-500.0</NoDataValue>
    <ImageOffset>0</ImageOffset>
    <PixelOffset>2</PixelOffset>
    <LineOffset>3600</LineOffset>
    <ByteOrder>LSB</ByteOrder>
  </VRTRasterBand>
</VRTDataset>
This VRT file can then be used as a regular GDAL dataset.
After having created all the VRT for each tile, you can generate a
global VRT file which is the mosaic of all tiles
I've created a section on my page http://even.rouault.free.fr/ with the
source code to generate all the .VRT files for each tile. There's also a
.ZIP with all the VRTs and the global VRT already generated.
Best regards,
Even
Helmut Kudrnovsky a écrit :
> hi,
> has anyone information if gdal is able to read "ACE - Altimeter Corrected Elevations"-DEM-data from ESA?
> overview ace2-data
> http://www.cse.dmu.ac.uk/EAPRS/products_ace_overview.html
> 3 SECOND DATASET - Data_Format_and_Source_3S
> http://tethys.eaprs.cse.dmu.ac.uk/ACE2/docs/Data_Format_and_Source_3S.doc
> best regards
> Helmut
> ______________________________________________________
> GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
> Jetzt freischalten unter http://movieflat.web.de
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
