[gdal-dev] Gdal / Python / Win7 crash with ReadAsArray()
Daniel Victoria daniel.victoria at gmail.com
Sat Jan 16 12:16:04 EST 2010
Python(x,y) comes with Numpy 1.3.0.
Some more info. ReadRaster() will sometimes work but sometimes not
(crashes). gdalinfo -checksum on the dataset works with no problem
whatsoever. And again, the same install on a XP machine works as
expected...
daniel
On Fri, Jan 15, 2010 at 7:43 PM, Christopher Barker
<Chris.Barker at noaa.gov> wrote:
> Daniel Victoria wrote:
>> I'm trying to use Gdal in a python program in Win7 (32 bit - portuguese).
>> I have python 2.6.2 and installed the gdal libraries following the
>> instructions in this page:
>> http://pypi.python.org/pypi/GDAL/
>> That is, I have the GDAL 1.6.1 python extension
>> (GDAL-1.6.1.win32-py2.6.exe) and installed Gdal 1.6
>> (gdalwin32exe160.zip).
> what numpy version are you using (though I'm not sure what numpy version
> that exe was built against). That may be an issue.
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R            (206) 526-6959   voice
> 7600 Sand Point Way NE   (206) 526-6329   fax
> Seattle, WA  98115       (206) 526-6317   main reception
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
