[gdal-dev] Can GDAL open binary buffer contents as input for MEM format?
Roger André randre at gmail.com
Sat Jan 16 15:48:42 EST 2010
Hi All,
I'd like to know if I can take the results of a MapServer Python mapscript
'mapImage.getBytes()' operation, and feed it into GDAL as a data source for
an in-memory raster?  The MapServer docs state that the results of
'getBytes' in Python is a "string of binary data".  I'm not sure if GDAL can
open this sort of object though.
For background purposes, the reason I would like to do this is so that I can
try replacing PIL with GDAL in TileCache for the cutting of metatiles.  PIL
isn't properly saving the image formats generated by MapServer, whereas GDAL
replicates them perfectly.
Thanks,
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100116/783ec7ce/attachment.html
