[gdal-dev] Can GDAL open binary buffer contents as input for MEM format?
Sat Jan 16 17:34:30 EST 2010
Roger André wrote:
> Hi Frank,
> Thanks for the example.  How can I specify alpha in that, for one of the
> quantized 8-bit PNG's (with alpha) that MapServer produces?
Roger,
In a way this is simplier.  It is just a one band GDT_Byte file, so more
like the first example I gave.  The palette can be handled separately,
and assigned to the MEM dataset a bit like:
     gdaltest.test_ct_data = [ (255,0,0), (0,255,0), (0,0,255), (255,255,255,0)]
     gdaltest.test_ct = gdal.ColorTable()
     for i in range(len(gdaltest.test_ct_data)):
         gdaltest.test_ct.SetColorEntry( i, gdaltest.test_ct_data[i] )
     mem_ds.GetRasterBand(1).SetColorTable( gdaltest.test_ct )
Best regards,
