[gdal-dev] Open source vector geoprocessing libraries?
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jan 18 05:38:23 EST 2010
On 17-1-2010 22:02, Mateusz Loskot wrote:
> Does that mean that I can use ogrinfo on a gzipped archive, like
>> gdalinfo (http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip)?
> Yes, it does but...as long as OGR driver performs filesystem
> operations using VSI*L API. The problem is that only few of them use VSI*L.
> As an example, I just updated OGR GeoJSON driver to use VSI*L API:
> http://trac.osgeo.org/gdal/changeset/18573
> As you can see, it is not a complex task, but may be time consuming and
> tedious, and requires quite a lot of testing.
> After these changes are applied, it is possible to (un)gzip GeoJSON
> datasets:
> 1) Translate Shapefile to GeoJSON file compressed using GZip:
> $ ogr2ogr -f GeoJSON /vsigzip/./points.geojson.gz points.shp
> 2) Read GZip compressed GeoJSON dataset:
> $ ogrinfo /vsigzip/./points.geojson.gz
> $ ogrinfo /vsigzip/./points.geojson.gz OGRGeoJSON
>> It would be a nice archive functionality.
> Yes, indeed.
> The work requires to step in to each OGR driver directory,
> grep .cpp files for VSI verify what VSI API is used.driver:
> For example, OGR Shapefile driver would, in theory, need to get
> updated VSI calls in about 50 places:
> $ grep VSI *.cpp | wc -ls
> 47
> I'm quite sure volunteers would be appreciated.
Thanks Mateusz. I am going to look at GeoJSON as an ASCII data archiving
format, as long as long as a full-fledged GML driver isn't available I
have always liked JSON more then XML.
Jan
