[gdal-dev] No PROJ.4 translation for source SRS
Smart, Gary Gary.Smart at goodrich.com
Tue Jan 19 08:36:16 EST 2010
I still can't get to the bottom of this message - can anyone explain
it...
ERROR 1:  No PROJ.4 translation for source SRS, coordinate
transformation initialization has failed.
I'm trying to convert the native coordinates in a file into WGS84
lat/longs.
However, when I create the OGRCoordinateTransformation (using the
importFromWkt for input source and setWellKnownGeogCS("WGS84") for
output) I get the above PROG.4 error.
NOTE - if I use the proj.4 library directly, it seems possible to
convert coords (e.g. converting WGS84 UTM  to WGS84 LatLong):
Proj4 code is something like...
projIn = pj_init_plus("+prof=utm +north +ellps=WGS84");
projOut = pj_init_plus("+prof=latlong +ellps=WGS84");
pj_transform(projIn, projOut, blah blah);
NOTE also that an old openEv executable I have, seems to be able to
georeference these files fine.
I am using Linux SLES10 SP2, gdal-svn-trunk-2009.12.14 and
proj4-4.7.0-1.
Any help welcome
Gary
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100119/b3a2fd1a/attachment.html
