[gdal-dev] Re: Altering the GeoTransform matrix with World files and VRT files
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Jan 26 10:58:15 EST 2010
Craig Leat <craig.leat <at> gmail.com> writes:
> Before I proceed much further I wish to pose two questions:
> 1. Is there a gdal environment variable I may have missed that can be
> used to give precedence to the world file?
> 2. Is there any freely available software that will modify the
> metadata tags in a sid file?
With Mapserver you can use:
PROCESSING "EXTENT_PRIORITY=WORLDFILE
More reading at
http://n2.nabble.com/
AGG-output-with-mapscript-C-5-2-problem-td1973340.html
I do not know how this feature could be utilised directly with gdal,
but it exists.
-Jukka Rahkonen-
