[gdal-dev] Support for GML 3
Even Rouault even.rouault at mines-paris.org
Tue Jan 26 14:22:36 EST 2010
Massimo,
it depends on if you're interested by the read side or the write side of the
GML driver !
* For the read side, it's designed for GML2 but some GML3 support has been
added . I see there's at least some support for the <pos> and <posList>
elements. The best is to try and see if it supports what you're interested
in !
* For the write side, GML2 only.
Best regards,
Even
Le Tuesday 26 January 2010 16:46:23 massimo costantini, vous avez écrit :
> Hi,
> I'd like to know, the state of the art for the GML3 data format
> support in ogr2ogr.
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
