[gdal-dev] Altering the GeoTransform matrix with World files and VRT files
Craig Leat craig.leat at gmail.com
Wed Jan 27 03:12:03 EST 2010
Hi Frank,
Frank Warmerdam wrote:
> The mechanism that Jukka mentions is MapServer-only.
> Reviewing the code, it appears that shapefiles are still
> just a fallback if no georeferencing is found internally.
> I am not aware of software for overriding mrsid georeferencing
> in the file.
Would it be considered too cheeky if I opened an enhancement ticket
for an environment variable (WORLDFILE_PRIORITY)? If the variable is
set a driver should use the worldfile instead of the internal
georeferencing.
Regards,
Craig
