[gdal-dev] Building GDAL Application gdal1.6.3 on VC++2008 Pro Edition Document
Tamas Szekeres szekerest at gmail.com
Wed Jan 27 08:34:47 EST 2010
Hi Vadivelan,
The GDAL build instructions should normally go to
http://trac.osgeo.org/gdal/wiki/BuildHints
If you see something missing here, feel free to edit the wiki with your
additional information.
Best regards,
Tamas
2010/1/27 vadi_nabble <vadivelan_gi at yahoo.co.in>
> Hi,
>  Last 2 weeks I was trying to build a GDAL application "gdal1.6.3" on VC++
> 2008 Pro Edition.
>  However, I was getting some compilation and Run time error on building and
> Running.
>  What I found is I need to set namke.opt file properly for successfull
> compilation and exection.
>  I have created on document which describes step by step procedure for
> building GDAL application and another application to use OGR APIs.
> Thanks,
> Vadivelan
> http://n2.nabble.com/file/n4467057/GDAL%2BBuilding%2Band%2BExecution%2BSteps.doc
> GDAL+Building+and+Execution+Steps.doc
> http://n2.nabble.com/Building-GDAL-Application-gdal1-6-3-on-VC-2008-Pro-Edition-Document-tp4467057p4467057.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100127/b1b532e4/attachment.html
