[gdal-dev] 1.7.0 compile with MSVC 2008 fails on NITF
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jan 27 12:09:52 EST 2010
Yewondwossen Assefa wrote:
> Jeff,
> I run into the same issue and my quick fix was to:
>  - cd gdal-1.7.0/frmts/jpeg
>  - nmake -f makefile.vc
>  and come back to the the main gdal-1.7.0/ and continue with the build
> The problem comes from the fact that jpeg12 needs to be build before
> nitf (that is where files such as jpeglib.h are copied into the jpeg12
> directory).
> You could do that until it is fixed properly in the makefiles.
Thanks Assefa, that quick fix works.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
