[gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Jez Walters Jez.Walters at ipl.com
Thu Jul 1 05:49:09 EDT 2010
Even,
This is precisely the fix I came up with yesterday, but I was wondering if there was a more "official" solution instead of editing the GML?
Warm regards,
Jez
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Wednesday 30 June 2010 19:54
To: gdal-dev at lists.osgeo.org
Cc: Jez Walters; 'Frank Warmerdam'
Subject: Re: [gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Jez,
the reason for the orientation field to be recognize in the CartographicSymbol
layer and not in the CartographicText layer lies in the structure of the GML
file and limitations of the OGR GML driver and/or OGR data model.
Namely OGR only supports a "flat" organization of fields whereas GML (being
XML based) supports a tree-like organization. In the CartographicSymbol
layer, the orientation element is at the first level, whereas in the
CartographicText, it is included inside the <textRendering> element, and then
is ignored (see below examples)
<osgb:CartographicSymbol fid='osgb1000000729439973'>
	<osgb:featureCode>10165</osgb:featureCode>
	<osgb:version>1</osgb:version>
	<osgb:versionDate>2001-11-11</osgb:versionDate>
	<osgb:theme>Rail</osgb:theme>
	<osgb:changeHistory>
		<osgb:changeDate>2001-03-12</osgb:changeDate>
		<osgb:reasonForChange>New</osgb:reasonForChange>
	</osgb:changeHistory>
	<osgb:descriptiveGroup>Rail</osgb:descriptiveGroup>
	<osgb:descriptiveTerm>Switch</osgb:descriptiveTerm>
	<osgb:orientation>3009</osgb:orientation>
	<osgb:physicalLevel>50</osgb:physicalLevel>
	<osgb:point>
		<gml:Point srsName='osgb:BNG'>
			<gml:coordinates>291781.470,92943.570</gml:coordinates>
		</gml:Point>
	</osgb:point>
</osgb:CartographicSymbol>
<osgb:CartographicText fid='osgb1000000729439996'>
	<osgb:featureCode>10026</osgb:featureCode>
	<osgb:theme>Buildings</osgb:theme>
	<osgb:anchorPoint>
		<gml:coordinates>291636.850,92668.150</gml:coordinates>
		</gml:Point>
	</osgb:anchorPoint>
		<osgb:changeDate>1987-12-01</osgb:changeDate>
	<osgb:descriptiveGroup>Buildings Or Structure</osgb:descriptiveGroup>
	<osgb:make>Manmade</osgb:make>
	<osgb:textRendering>
		<osgb:anchorPosition>3</osgb:anchorPosition>
		<osgb:font>2</osgb:font>
		<osgb:height>1.500</osgb:height>
		<osgb:orientation>545</osgb:orientation>
	</osgb:textRendering>
	<osgb:textString>44</osgb:textString>
</osgb:CartographicText>
We could imagine an enhancement of the GML driver to try to "flatten" the
attributes. For example to return textRendering_anchorPosition,
textRendering_font, .... But it doesn't look trivial to add.
To workaround this, you can open the GML with your favorite text editor (or
sed ;-)) and replace <osgb:textRendering> and </osgb:textRendering> by
nothing
This works nicely ;-)
Best regards,
Even
Le Wednesday 30 June 2010 17:17:12 Jez Walters, vous avez écrit :
> Frank,
> Thanks for looking in to this!  I've just repeated the problem with the
> Ordnance Survey sample MasterMap, which is available from here:
> http://www.ordnancesurvey.co.uk/oswebsite/products/innovations/sampledata/O
>SMasterMap_Topo/58116-SX9192-2c1.gz
> I tried converting the above GML to ESRI shapefile using the following
> command:
> ogr2ogr SX9192 58116-SX9192-2c1
> One thing I've noticed is that the schema referenced in the GML
> (http://www.ordnancesurvey.co.uk/xml/schema/v7/OSDNFFeatures.xsd) defines a
> number of elements called "complexType".  The "complexType" element with a
> name of "CartographicTextType" is defined like this:
> <complexType name="CartographicTextType">
> 	<complexContent>
> 		<extension base="osgb:AbstractFeatureType">
> 			<sequence>
> 				<element name="anchorPoint" type="gml:PointPropertyType"/>
> 				<element name="changeHistory" type="osgb:changeHistoryType"
> maxOccurs="unbounded"/> <element name="descriptiveGroup"
> type="osgb:descriptiveGroupType" minOccurs="0" maxOccurs="unbounded"/>
> <element name="descriptiveTerm" type="string" minOccurs="0"
> maxOccurs="unbounded"/> <element name="make" type="osgb:makeType"
> minOccurs="0"/>
> 				<element name="physicalLevel" type="osgb:physicalLevelType"/>
> 				<element name="physicalPresence" type="osgb:physicalPresenceType"
> minOccurs="0"/> <element name="textRendering"
> type="osgb:textRenderingType"/>
> 				<element name="textString" type="string"/>
> 			</sequence>
> 		</extension>
> 	</complexContent>
> </complexType>
> >From which I conclude that the orientation is actually part of the
> > "textRendering" element.  I'm sure I'm on to something with this, but I'm
> > not sure how to proceed from here!
> Warm regards,
> Jez
> From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
> Warmerdam Sent: Wednesday 30 June 2010 15:38
> To: Jez Walters
> Cc: gdal-dev at lists.osgeo.org
> MasterMap
> Jez,
> Can you provide a mastermap file I can test with?
> Best regards,
> On Wed, Jun 30, 2010 at 4:31 PM, Jez Walters <jez.walters at ipl.com> wrote:
> > Not quite sure if I've got the right forum, but I'm having trouble using
> > the 'ogr2ogr' utility (part of GDAL 1.7.2) to convert Ordnance Survey GML
> > into ESRI shapefiles.
> > The 'orientation' field is being ignored when I convert the
> > CartographicText layer, although this field gets successfully translated
> > for the
> > CartographicSymbol layer.  All the other CartographicText layer fields
> > appear just fine in the generated '.dbf' file.
> > Is there a way of forcing ogr2ogr to recognise the orientation field?
> >  Can anyone suggest an alternative Open Source conversion utility?  I'm
> > fairly new to GIS systems, so I might be making an obvious mistake, but
> > any advice is very gratefully received!  :-)
> > View this message in context:
> > http://osgeo-org.1803224.n2.nabble.com/ogr2ogr-problem-converting-UK-Ordn
> >ance-Survey-MasterMap-tp5237796p5237796.html Sent from the GDAL - Dev
> > mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
The information transmitted is intended only for the person
or entity to which it is addressed and may contain
confidential and/or privileged material. If you are not the
addressee, any disclosure, reproduction, copying,
distribution, or other dissemination or use of this
communication is strictly prohibited. If you have received
this transmission in error please notify the sender
immediately and then delete this email.
Any representations or commitments expressed in this email
are subject to contract.
This message has been scanned for viruses and dangerous
content. However, it is essential that the recipient also
checks this message using commercially available mail
scanning and anti-virus software. IPL Information Processing
Limited accepts no liability for any loss or damage resulting
from any virus or other dangerous content in this message.
IPL Information Processing Limited is registered in England
and Wales under company registration number 1418818.
Registration took place at Cardiff on 10 May 1979. IPL
Information Processing Limited's registered office and
normal place of business is Eveleigh House, Grove Street,
Bath, BA1 5LR, United Kingdom. IPL is also registered for
Value Added Tax (VAT) under registration number GB 601 2931 83.
