[gdal-dev] Re: C# bindings compile error VSE 2010
Tomas R monshi at home.se
Thu Jul 1 07:01:11 EDT 2010
  Ok, will download that version.... done... and it compiled ok. As
simple as that :)
How about the target platform? Should be easy to set it to .Net2 but
how?  Now it compiles to .Net4.The version on dyndns is also targeted at
.Net4 I notice.
Thanks
/tomas
Tamas Szekeres skrev 2010-07-01 12:41:
> Tomas,
> You should use SWIG 1.3.39. The bindings haven't been tested with SWIG
> 2.0.0. Upgrading SWIG always cause much of pain...
> Best regards,
> Tamas
> 2010/7/1 Tomas R <monshi at home.se <mailto:monshi at home.se>>
>      Back again trying to compile gdal and the C# interface. This time
>     with VSE 2010, Gdal 1.7.2 and Swig 2.0.0 on a Vista32 machine
>     Gdal compiles fine, no problems, but the C# bindings fail with the
>     following error when using nmake:
>            csc /platform:x86  /target:library /out:gdal_csharp.dll
>     /r:ogr_csharp.dl
>     l gdal\*.cs AssemblyInfo.cs
>     Microsoft (R) Visual C# 2010 Compiler version 4.0.30319.1
>     Copyright (C) Microsoft Corporation. All rights reserved.
>     gdal\Band.cs(17,79): error CS0117: 'OSGeo.GDAL.GdalPINVOKE' does
>     not contain a
>            definition for 'BandUpcast'
>     gdal\Dataset.cs(17,82): error CS0117: 'OSGeo.GDAL.GdalPINVOKE'
>     does not contain
>            a definition for 'DatasetUpcast'
>     gdal\Driver.cs(17,81): error CS0117: 'OSGeo.GDAL.GdalPINVOKE' does
>     not contain a
>            definition for 'DriverUpcast'
>     NMAKE : fatal error U1077:
>     'C:\Windows\Microsoft.NET\Framework\v4.0.30319\csc.EX
>     E' : return code '0x1'
>     Stop.
>     Since I am, and always will be, a newbie on C++ compilation I have
>     no idea what to do to fix it or if I can fix it.
>     And since I am asking here I throw in another Q - I want to target
>     the C# bindings to the .Net2 platform. How/where can I control
>     this via the commandline compiler, via the nmake command?
>     Yours
>     Tomas
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
