[gdal-dev] Re: C# bindings compile error VSE 2010
Tamas Szekeres szekerest at gmail.com
Thu Jul 1 14:31:58 EDT 2010
Good to hear it's working. The dyndns builds use the default framework
version per compiler.
Best regards,
Tamas
2010/7/1 Tomas R <monshi at home.se>
>  Set
> @SET FrameworkVersion=v2.0.50727
> in vcvars32.bat seems to work...
> Yours
> Tomas
> Tomas R skrev 2010-07-01 13:01:
>   Ok, will download that version.... done... and it compiled ok. As simple
>> as that :)
>> How about the target platform? Should be easy to set it to .Net2 but how?
>>  Now it compiles to .Net4.The version on dyndns is also targeted at .Net4 I
>> notice.
>> Thanks
>> /tomas
>> Tamas Szekeres skrev 2010-07-01 12:41:
>>> Tomas,
>>> You should use SWIG 1.3.39. The bindings haven't been tested with SWIG
>>> 2.0.0. Upgrading SWIG always cause much of pain...
>>> Best regards,
>>> Tamas
>>> 2010/7/1 Tomas R <monshi at home.se <mailto:monshi at home.se>>
>>>     Back again trying to compile gdal and the C# interface. This time
>>>    with VSE 2010, Gdal 1.7.2 and Swig 2.0.0 on a Vista32 machine
>>>    Gdal compiles fine, no problems, but the C# bindings fail with the
>>>    following error when using nmake:
>>>           csc /platform:x86  /target:library /out:gdal_csharp.dll
>>>    /r:ogr_csharp.dl
>>>    l gdal\*.cs AssemblyInfo.cs
>>>    Microsoft (R) Visual C# 2010 Compiler version 4.0.30319.1
>>>    Copyright (C) Microsoft Corporation. All rights reserved.
>>>    gdal\Band.cs(17,79): error CS0117: 'OSGeo.GDAL.GdalPINVOKE' does
>>>    not contain a
>>>           definition for 'BandUpcast'
>>>    gdal\Dataset.cs(17,82): error CS0117: 'OSGeo.GDAL.GdalPINVOKE'
>>>    does not contain
>>>           a definition for 'DatasetUpcast'
>>>    gdal\Driver.cs(17,81): error CS0117: 'OSGeo.GDAL.GdalPINVOKE' does
>>>    not contain a
>>>           definition for 'DriverUpcast'
>>>    NMAKE : fatal error U1077:
>>>    'C:\Windows\Microsoft.NET\Framework\v4.0.30319\csc.EX
>>>    E' : return code '0x1'
>>>    Stop.
>>>    Since I am, and always will be, a newbie on C++ compilation I have
>>>    no idea what to do to fix it or if I can fix it.
>>>    And since I am asking here I throw in another Q - I want to target
>>>    the C# bindings to the .Net2 platform. How/where can I control
>>>    this via the commandline compiler, via the nmake command?
>>>    Yours
>>>    Tomas
>>>    _______________________________________________
>>>    gdal-dev mailing list
>>>    gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>>    http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100701/e8ea4d42/attachment.html
