[gdal-dev] Re: Bug(?): RIK-maps with Gdal 1.7.2 do not work
Tomas R monshi at home.se
Tue Jul 6 09:13:37 EDT 2010
  I add - perhaps a problem with my comilation of Gdal.  Note when I
compile the GdalReadDirect.cs as it is and run it the result differs
from the result of the GdalReadDirect.exe found in Swig\Csharp.
The latter gives the Raster dataset Paramets and runs until an Out of
memory Exception. Mine hangs and I have to abort it.
What have I done wrong this time?
Will try to recompile gdal and see if anything changes.
Tomas R skrev 2010-07-06 14:16:
>  I have a problem with RIK-maps and Gdal 1.7.2.
> If I use Gdal 1.6.1 I have no problem reading the map but doing the
> same with Gdal 1.7.2 my whole plugin/software hangs.
> I have identified that Gdal stops at the line
>  band.ReadRaster(x, y, width, height, r, width, height, 0, 0);
> where x, y, width and height are controlled to be within the image to
> load.
> This line taken from the routine
>   private void SaveBitmapPaletteDirect(...)
> from the C# samples. I have adapted it to load only a portion of the
> map into a bitmap.
> I have compiled Gdal myself, perhaps a problem with the compilation?
> Do I miss the RIK-driver or something? Or is there an error in Gdal?
> Or perhaps in the file(s)?
> I have no problem opening and getting the properties of the file, i.e.
> coordinate system and alike. It is when I try to read the file that
> Gdal hangs.
> I get no Exception, it just hangs and eats CPU-time.
> I  compile the C# sample GDALReadDirect.cs from Gdal 1.7.2 and adapt
> it to read a portion of a big RIK file (500x500 pixels) and it stops
> at the same point in code. Error in the driver for RIK perhaps? or
> error in the sample code?
> Yours
> Tomas
