[gdal-dev] Re: Writing non-ASCII characters to shapefile
Hermann Peifer peifer at gmx.eu
Tue Jul 6 12:44:32 EDT 2010
In the mentioned mail from earlier this year, William Kyngesburye wrote:
 > Maybe GDAL needs a creation option in the shapefile driver
 > to set the LDID or to instead add a cpg file with an encoding value.
As there was no reply to his mail, I assume that there is no GDAL/OGR
creation option for the LDID and it is unlikely that there will be one
in the near future.
Hermann
On 06/07/2010 13:04, Francis Markham wrote:
> It appears from
> http://lists.osgeo.org/pipermail/gdal-dev/2010-May/024619.html and
> http://resources.arcgis.com/content/kbase?fa=articleShow&d=26015  that
> ESRI set the LDID to zero to indicate an unknown LDID.  From my
> reading of the OGR sourcecode, it seems that OGR uses the shapelib
> default LDID of 0x57 (previously it was set to 0x3, or windows-1252).
> Is there any way to specify this value using the OGR API, or do I need
> to use shapelib directly to create my shapefiles in order to do this?
> Cheers,
> Francis
> On 6 July 2010 18:31, Hermann Peifer<peifer at gmx.eu>  wrote:
>> The .cpg files we generate through ArcGIS desktop contain the string: UTF-8
>> Some time ago, there was a mail on this list about problems in case of
>> conflicting information in the .cpg file compared to the Language Driver ID
>> (LDID) in the header of a dBASE file, see:
>> Hermann
>> On 06/07/2010 04:13, Francis Markham wrote:
>> Okay, I will take that approach then.  Thank you all for your help.
>> What specific value should I write into the .cpg? The string '65001'
>> or the string 'utf-8' or something else?
>> -Francis
>> On 5 July 2010 21:53, Peter Hopfgartner<peter.hopfgartner at r3-gis.com>
>> wrote:
>> Hi Francis,
>> what does not portable mean? ArcMap handles UTF-8 fine, if the correct
>> encoding is written into the .cpg file. Recent shapelib should handle
>> this fine, too. If there is any problem with a specific GIS program, a
>> bug report for that GIS program might be the right thing to do.
>> Regards,
>> Peter
>> On Mon, 2010-07-05 at 19:18 +1000, Francis Markham wrote:
>> At the bottom of this page, for one:
>> http://resources.arcgis.com/content/kbase?fa=articleShow&d=21106
>> But honestly I've found hard to find  information about this.  I'd be
>> very happy to be corrected if this is not the case!
>> Cheers,
>> Francis
>> On 5 July 2010 19:09, Hermann Peifer<peifer at gmx.eu>  wrote:
>> Francis, you wrote:
>> I have heard that the use of UTF-8 in shapefiles is not portable.
>> Where did you hear this?
>> Regards, Hermann
>> On 03/07/2010 04:40, Francis Markham wrote:
>> Hi there,
>> I'm trying to write data from a Microsoft Excel .xls file into a
>> shapefile, using OGR's Python bindings in Python 2.6.  This is going
>> well, but I am having some problems when I try to write values that
>> contain so-called "smart quotes".  Smart quotes are special
>> characters, defined as characters 0x91 through 0x94 in Windows-1252 (
>> see http://msdn.microsoft.com/en-au/goglobal/cc305145.aspx ).
>> What is the best way to save this data to a shapefile using OGR?  I
>> need the shapefile to be interoperable with other programs, including
>> but not limited to ESRI products. While I assume I could simply
>> translate these characters to standard ASCII, I would prefer not to if
>> possible.  I also haven't tested the shapefiles with data from other
>> character encodings.
>> I have heard that the use of UTF-8 in shapefiles is not portable.  I
>> am also aware that shapefile.cpg can store a shapefile's codepage.  I
>> don't know how to put these pieces together to create a portable
>> solution, however.
>> Apologies if this is a newbie question, but I can't find answers on the
>> web.
>> Thanks,
>> Francis Markham
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Dott. Peter Hopfgartner
>> R3 GIS Srl - GmbH
>> Via Johann Kravogl-Str. 2
>> I-39012 Meran/Merano (BZ)
>> Email: peter.hopfgartner at r3-gis.com
>> Tel. : +39 0473 494949
>> Fax  : +39 0473 069902
>> www  : http://www.r3-gis.com
>> XING : http://www.xing.com/go/invita/8917535
