[gdal-dev] Re: Bug(?): RIK-maps with Gdal 1.7.2 do not work
Tomas R monshi at home.se
Tue Jul 6 14:02:55 EDT 2010
  So a solution/a fix is available when 1.7.3 is released somewhere in
the future? That somewhere might occur when?
If you are correct that is. But of course you are....
/Tomas
Even Rouault skrev 2010-07-06 19:46:
> Chaitanya,
> Actually I think I've spotted the regression in
> http://trac.osgeo.org/gdal/changeset/17398, which was a 1.7 change.
> Namely the change from
> int i;
> for( i = 0; i<  LZW_CLEAR; i++ )
> 	character[i] = i;
> to
> GByte j;
> for( j = 0; j<  LZW_CLEAR; j++ )
> 	character[j] = j;
> The issue is that LZW_CLEAR = 256, so as j is an unsigned char - restricted
> from 0 to 255 -, the j<  LZW_CLEAR condition is always true, thus the
> infinite loop...
> This part should be reverted. If you really want to shut up the compiler
> warning character[i] = (GByte)i but in an ideal world, the compiler should be
> clever enough to see that there's no risk of data loss as i does fit in a
> GByte...
> Best regards,
> Even
> Le Tuesday 06 July 2010 19:18:56 Tomas R, vous avez écrit :
>>    The reason for the out of memory exception was because the RIK-map I
>> tested with i wasfar to big to be read into a bitmap. I have now created
>> a smaller sample.
>> With the small RIK-fil I can reproduce the problem with the precompiled
>> binaries from dyndns so problem is not only on my part. Using the small
>> map (1000x750 pixels) the demo app from Gdal 1.6.1 works as it should.
>> 1.7.2 hangs with no exception given.
>> See ticket http://trac.osgeo.org/gdal/ticket/3674
>> The post you answered  I tried to delete and somewhat succeeded... I
>> happened to compile the wrong file. When I thought I was compiling the
>> GDALReadDirect.cs I instead compiled the GDALRead.cs.
>> Yours
>> Tomas
>> Chaitanya kumar CH skrev 2010-07-06 18:24:
>>> Tomas,
>>> I don't see any changes that could lead to infinite loops or memory
>>> leaks recently.
>>> If you can provide a sample dataset that gives this error please raise
>>> a ticket at http://trac.osgeo.org/gdal/newticket
>>> On Tue, Jul 6, 2010 at 6:43 PM, Tomas R<monshi at home.se
>>> <mailto:monshi at home.se>>  wrote:
>>>       I add - perhaps a problem with my comilation of Gdal.  Note when
>>>      I compile the GdalReadDirect.cs as it is and run it the result
>>>      differs from the result of the GdalReadDirect.exe found in
>>>      Swig\Csharp.
>>>      The latter gives the Raster dataset Paramets and runs until an Out
>>>      of memory Exception. Mine hangs and I have to abort it.
>>>      What have I done wrong this time?
>>>      Will try to recompile gdal and see if anything changes.
>>>      Tomas R skrev 2010-07-06 14:16:
>>>           I have a problem with RIK-maps and Gdal 1.7.2.
>>>          If I use Gdal 1.6.1 I have no problem reading the map but
>>>          doing the same with Gdal 1.7.2 my whole plugin/software hangs.
>>>          I have identified that Gdal stops at the line
>>>           band.ReadRaster(x, y, width, height, r, width, height, 0, 0);
>>>          where x, y, width and height are controlled to be within the
>>>          image to load.
>>>          This line taken from the routine
>>>           private void SaveBitmapPaletteDirect(...)
>>>          from the C# samples. I have adapted it to load only a portion
>>>          of the map into a bitmap.
>>>          I have compiled Gdal myself, perhaps a problem with the
>>>          compilation? Do I miss the RIK-driver or something? Or is
>>>          there an error in Gdal?  Or perhaps in the file(s)?
>>>          I have no problem opening and getting the properties of the
>>>          file, i.e. coordinate system and alike. It is when I try to
>>>          read the file that Gdal hangs.
>>>          I get no Exception, it just hangs and eats CPU-time.
>>>          I  compile the C# sample GDALReadDirect.cs from Gdal 1.7.2 and
>>>          adapt it to read a portion of a big RIK file (500x500 pixels)
>>>          and it stops at the same point in code. Error in the driver
>>>          for RIK perhaps? or error in the sample code?
>>>          Yours
>>>          Tomas
>>>      _______________________________________________
>>>      gdal-dev mailing list
>>>      gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
>>>      http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
