[gdal-dev] Convert huge PNG file to JP2
Wed Jul 7 12:28:04 EDT 2010
Gajera Tejas wrote:
> Hi All,
> Can I convert huge PNG image to JP2 using GDAL.
> Thanks in advance.
Tejas,
Yes, assuming you have a JPEG2000 driver enabled in GDAL (there are none
in a default build). For instance, if you have built against the Kakadu
library you could do:
  gdal_translate -of JP2KAK in.png out.jp2
Best regards,
