[gdal-dev] Re: Bug(?): RIK-maps with Gdal 1.7.2 do not work
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Jul 7 13:52:05 EDT 2010
Tomas,
Yes, you can patch the file rikdataset.cpp in 1.7.2 using
http://trac.osgeo.org/gdal/changeset/19986 and compile it.
There have been no other changes.
On Wed, Jul 7, 2010 at 10:28 PM, Tomas R <monshi at home.se> wrote:
>  The fix in
> http://trac.osgeo.org/gdal/changeset/19985
> I can download and replace the file in the 1.7.2 version of gdal I have and
> compile gdal again and it will work?
> Or should I wait for 1.7.3?
> Yours
> Tomas
> Tomas R skrev 2010-07-06 20:02:
>   So a solution/a fix is available when 1.7.3 is released somewhere in the
>> future? That somewhere might occur when?
>> If you are correct that is. But of course you are....
>> /Tomas
>> Even Rouault skrev 2010-07-06 19:46:
>>> Chaitanya,
>>> Actually I think I've spotted the regression in
>>> http://trac.osgeo.org/gdal/changeset/17398, which was a 1.7 change.
>>> Namely the change from
>>> int i;
>>> for( i = 0; i<  LZW_CLEAR; i++ )
>>>    character[i] = i;
>>> to
>>> GByte j;
>>> for( j = 0; j<  LZW_CLEAR; j++ )
>>>    character[j] = j;
>>> The issue is that LZW_CLEAR = 256, so as j is an unsigned char -
>>> restricted
>>> from 0 to 255 -, the j<  LZW_CLEAR condition is always true, thus the
>>> infinite loop...
>>> This part should be reverted. If you really want to shut up the compiler
>>> warning character[i] = (GByte)i but in an ideal world, the compiler
>>> should be
>>> clever enough to see that there's no risk of data loss as i does fit in a
>>> GByte...
>>> Best regards,
>>> Even
>>> Le Tuesday 06 July 2010 19:18:56 Tomas R, vous avez écrit :
>>>>   The reason for the out of memory exception was because the RIK-map I
>>>> tested with i wasfar to big to be read into a bitmap. I have now created
>>>> a smaller sample.
>>>> With the small RIK-fil I can reproduce the problem with the precompiled
>>>> binaries from dyndns so problem is not only on my part. Using the small
>>>> map (1000x750 pixels) the demo app from Gdal 1.6.1 works as it should.
>>>> 1.7.2 hangs with no exception given.
>>>> See ticket http://trac.osgeo.org/gdal/ticket/3674
>>>> The post you answered  I tried to delete and somewhat succeeded... I
>>>> happened to compile the wrong file. When I thought I was compiling the
>>>> GDALReadDirect.cs I instead compiled the GDALRead.cs.
>>>> Yours
>>>> Tomas
>>>> Chaitanya kumar CH skrev 2010-07-06 18:24:
>>>>> Tomas,
>>>>> I don't see any changes that could lead to infinite loops or memory
>>>>> leaks recently.
>>>>> If you can provide a sample dataset that gives this error please raise
>>>>> a ticket at http://trac.osgeo.org/gdal/newticket
>>>>> On Tue, Jul 6, 2010 at 6:43 PM, Tomas R<monshi at home.se
>>>>> <mailto:monshi at home.se>>  wrote:
>>>>>      I add - perhaps a problem with my comilation of Gdal.  Note when
>>>>>     I compile the GdalReadDirect.cs as it is and run it the result
>>>>>     differs from the result of the GdalReadDirect.exe found in
>>>>>     Swig\Csharp.
>>>>>     The latter gives the Raster dataset Paramets and runs until an Out
>>>>>     of memory Exception. Mine hangs and I have to abort it.
>>>>>     What have I done wrong this time?
>>>>>     Will try to recompile gdal and see if anything changes.
>>>>>     Tomas R skrev 2010-07-06 14:16:
>>>>>          I have a problem with RIK-maps and Gdal 1.7.2.
>>>>>         If I use Gdal 1.6.1 I have no problem reading the map but
>>>>>         doing the same with Gdal 1.7.2 my whole plugin/software hangs.
>>>>>         I have identified that Gdal stops at the line
>>>>>          band.ReadRaster(x, y, width, height, r, width, height, 0, 0);
>>>>>         where x, y, width and height are controlled to be within the
>>>>>         image to load.
>>>>>         This line taken from the routine
>>>>>          private void SaveBitmapPaletteDirect(...)
>>>>>         from the C# samples. I have adapted it to load only a portion
>>>>>         of the map into a bitmap.
>>>>>         I have compiled Gdal myself, perhaps a problem with the
>>>>>         compilation? Do I miss the RIK-driver or something? Or is
>>>>>         there an error in Gdal?  Or perhaps in the file(s)?
>>>>>         I have no problem opening and getting the properties of the
>>>>>         file, i.e. coordinate system and alike. It is when I try to
>>>>>         read the file that Gdal hangs.
>>>>>         I get no Exception, it just hangs and eats CPU-time.
>>>>>         I  compile the C# sample GDALReadDirect.cs from Gdal 1.7.2 and
>>>>>         adapt it to read a portion of a big RIK file (500x500 pixels)
>>>>>         and it stops at the same point in code. Error in the driver
>>>>>         for RIK perhaps? or error in the sample code?
>>>>>         Yours
>>>>>         Tomas
>>>>>     _______________________________________________
>>>>>     gdal-dev mailing list
>>>>>     gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
>>>>>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Best regards,
>>>>> Chaitanya kumar CH.
>>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>>> +91-9494447584
>>>>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100707/5466695c/attachment-0001.html
