[gdal-dev] Oracle GeoRaster loading problem
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Jul 8 20:35:07 EDT 2010
Yes, if you see on ticket #3673 there is an example of sdo_geor.addNodata() with arrays of value
ranges as nodata but you can do it with just one value as nodata too. That fix will be available
shortly on GDAL trunk.
Pasta Bolognese wrote:
> ooo... is there any workaround ?
> Even any query to run in order to fix the XML... ?
> On Thu, Jul 8, 2010 at 5:11 PM, Ivan Lucena <ivan.lucena at pmldnet.com
> <mailto:ivan.lucena at pmldnet.com>> wrote:
>     See http://trac.osgeo.org/gdal/ticket/3673
>     >  -------Original Message-------
>     >  From: Pasta Bolognese <pasta.bolognese at gmail.com
>     <mailto:pasta.bolognese at gmail.com>>
>     >  To: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     >  Subject: [gdal-dev] Oracle GeoRaster loading problem
>     >  Sent: Jul 08 '10 11:06
>     >  Hi All,
>     >  after loading a raster, I've did the traditional
>     >  SELECT id, sdo_geor.validategeoraster(georaster) isvalid from
>     arcviewgrid;
>     >  and I've got: 1 13454 ([LINK: http://ora-13454.ora-code.com/]
>     >  http://ora-13454.ora-code.com/)
>     >  therefore I've run
>     >  SELECT sdo_geor.schemaValidate(georaster) from arcviewgrid;
>     >  ORA-31154: invalid XML document
>     >  ORA-19202: Error occurred in XML processing
>     >  LSX-00204: extra data at end of complex element
>     >  ORA-06512: at "SYS.XMLTYPE", line 354
>     >  ORA-06512: at "MDSYS.SDO_GEOR", line 3263
>     >  31154. 00000 -  "invalid XML document"
>     >  *Cause:    The XML document is invalid with respect to its XML
>     Schema.
>     >  *Action:   Fix the errors identified and try again.
>     >  that means that GDAL GeoRaster is generating a wrong metadata XML..
>     >  Any Ideas ?
>     >  thanks !
>     >  _______________________________________________
>     >  gdal-dev mailing list
>     >  [LINK: compose.php?to=gdal-dev at lists.osgeo.org
>     <mailto:gdal-dev at lists.osgeo.org>] gdal-dev at lists.osgeo.org
>     >  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
