[gdal-dev] Oracle GeoRaster loading problem
Pasta Bolognese pasta.bolognese at gmail.com
Fri Jul 9 04:15:28 EDT 2010
I mean, after having loaded the data with the *actual* GDAL, is there any
way to fix the already created XML ? something like:
read XML
fix it
write XML
The reason that I am asking if because I have some urgency in loading maps
and other tools (I have tried FME) wont load georeference data (coordinate
system)..... I guess that if it is fixed in the trunk, in will take "few"
weeks until it gets into OSGeo4W installer.
thanks
On Fri, Jul 9, 2010 at 1:35 AM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> Yes, if you see on ticket #3673 there is an example of sdo_geor.addNodata()
> with arrays of value
> ranges as nodata but you can do it with just one value as nodata too. That
> fix will be available
> shortly on GDAL trunk.
> Pasta Bolognese wrote:
> > ooo... is there any workaround ?
> > Even any query to run in order to fix the XML... ?
> > On Thu, Jul 8, 2010 at 5:11 PM, Ivan Lucena <ivan.lucena at pmldnet.com
> > <mailto:ivan.lucena at pmldnet.com>> wrote:
> >     See http://trac.osgeo.org/gdal/ticket/3673
> >     >  -------Original Message-------
> >     >  From: Pasta Bolognese <pasta.bolognese at gmail.com
>  >     <mailto:pasta.bolognese at gmail.com>>
> >     >  To: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> >     >  Subject: [gdal-dev] Oracle GeoRaster loading problem
> >     >  Sent: Jul 08 '10 11:06
> >     >  Hi All,
> >     >  after loading a raster, I've did the traditional
> >     >  SELECT id, sdo_geor.validategeoraster(georaster) isvalid from
> >     arcviewgrid;
> >     >  and I've got: 1 13454 ([LINK: http://ora-13454.ora-code.com/]
> >     >  http://ora-13454.ora-code.com/)
> >     >  therefore I've run
> >     >  SELECT sdo_geor.schemaValidate(georaster) from arcviewgrid;
> >     >  ORA-31154: invalid XML document
> >     >  ORA-19202: Error occurred in XML processing
> >     >  LSX-00204: extra data at end of complex element
> >     >  ORA-06512: at "SYS.XMLTYPE", line 354
> >     >  ORA-06512: at "MDSYS.SDO_GEOR", line 3263
> >     >  31154. 00000 -  "invalid XML document"
> >     >  *Cause:    The XML document is invalid with respect to its XML
> >     Schema.
> >     >  *Action:   Fix the errors identified and try again.
> >     >  that means that GDAL GeoRaster is generating a wrong metadata
> XML..
> >     >  Any Ideas ?
> >     >  thanks !
> >     >  _______________________________________________
> >     >  gdal-dev mailing list
> >     >  [LINK: compose.php?to=gdal-dev at lists.osgeo.org
> >     <mailto:gdal-dev at lists.osgeo.org>] gdal-dev at lists.osgeo.org
>  >     >  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100709/0d4e6e17/attachment.html
