[gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Even Rouault even.rouault at mines-paris.org
Sun Jul 11 06:12:25 EDT 2010
Just to inform you that now that the NAS driver is in GDAL trunk, I've been
able to port its enhancements to the main GML driver. On the few samples I've
tested, OS Mastermap GML files seem to be read correctly now.
See http://trac.osgeo.org/gdal/ticket/3680
Le Friday 02 July 2010 09:04:38 Martin Daly, vous avez écrit :
> >     Here it is not only GDAL/OGR that has a problem!  Currently, I know
> > of no importer that can handle this construct, other than the tool (from
> > Snowflake) used by OSGB to generate it - and there is also the question
> > of onwards storage.
> Not even close, I'm afraid.
> There are plenty of tools to read (all parts of) OS MM:
> http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/information/
>technical/software.html
> e.g. (an excellent one, at a very reasonable price...)
>technical/software/cadcorp.html
> Also, as far as I am aware, OS GB use in-house software to generate the
> data.
> Martin
>* This email is confidential and may be privileged and should not be used,
> read or copied by anyone who is not the  original intended recipient. If
> you have received this email in error  please inform the sender and delete
> it from your mailbox or any other storage mechanism. Unless specifically
> stated, nothing in this email constitutes an offer by Cadcorp and Cadcorp
> does not warrant that any information contained in this email is accurate.
> Cadcorp cannot accept liability for any statements made which are clearly
> the sender's own and not expressly made on behalf of Cadcorp or one of its
> agents. Please rely on your own virus check. No responsibility is taken by
> Cadcorp for any damage arising out of any bug or virus infection.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
