[gdal-dev] GeoRaster: problem updating on predefined existing table
Pasta Bolognese pasta.bolognese at gmail.com
Mon Jul 12 05:33:48 EDT 2010
Hi All,
following http://www.gdal.org/frmt_georaster.html I've imported a
small immage using:
C:\>gdal_translate -of georaster  c:\tmp\map.png
georaster:geoserver/geoserver,MFDEVDB
and it works well. Then I've imported another immage using the same
command and it worked well too !
Then I have decided to use a predefined table.... and here the problems:
georaster:geoserver/geoserver,MFDEVDB,geoserver.pasta
Input file size is 1014, 863
0...10...20...30...40...50...60...70...80...90...100 - done.
Ouput dataset: (georaster:geoserver,geoserver,MFDEVDB,RDT_33$,33) on
PASTA,RASTER
ERROR 1: ORA-00955: name is already used by an existing object
ORA-06512: at line 10
ERROR 1: Create Table Error!
any ideas ?
how can I update an existing raster on an existing table ?
thanks
