Re: [gdal-dev] GeoRaster: problem updating on predefined existing table
Ivan Lucena ivan.lucena at pmldnet.com
Mon Jul 12 07:38:16 EDT 2010
>  -------Original Message-------
>  From: Pasta Bolognese <pasta.bolognese at gmail.com>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] GeoRaster: problem updating on predefined existing table
>  Sent: Jul 12 '10 04:33
>  Hi All,
>  following http://www.gdal.org/frmt_georaster.html I've imported a
>  small immage using:
>  C:\>gdal_translate -of georaster  c:\tmp\map.png
>  georaster:geoserver/geoserver,MFDEVDB
>  and it works well. Then I've imported another immage using the same
>  command and it worked well too !
Note that you didn't specify table & column so a table named "GDAL_IMPORT", column "RASTER" was created for you as default.
>  Then I have decided to use a predefined table.... and here the problems:
>  georaster:geoserver/geoserver,MFDEVDB,geoserver.pasta
This command is missing the column name after "schema.table" so it is assuming column name "RASTER" as default. Does the table "pasta" existed before that command?
>  Input file size is 1014, 863
>  0...10...20...30...40...50...60...70...80...90...100 - done.
>  Ouput dataset: (georaster:geoserver,geoserver,MFDEVDB,RDT_33$,33) on
>  PASTA,RASTER
>  ERROR 1: ORA-00955: name is already used by an existing object
>  ORA-06512: at line 10
>  ERROR 1: Create Table Error!
Again, this command is missing the column name too, so I believe it is trying to re-create the table "Pasta" with column "RASTER". Whatever is happening is caused by the error on the command.
Please, see more info at: http://www.oracle.com/technology/products/spatial/htdocs/spatial_opensource.html
Regards.
>  any ideas ?
>  how can I update an existing raster on an existing table ?
>  thanks
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
