[gdal-dev] ogr2ogr problem converting UK Ordnance Survey MasterMap
Even Rouault even.rouault at mines-paris.org
Mon Jul 12 17:09:18 EDT 2010
Jez,
if you checkout latest GDAL trunk, you'll find a new -splitlistfields option
for ogr2ogr that will split fields of type IntegerList, RealList or
StringList into as many subfields of single type as necessary. You can also
specify -maxsubfields an_integer_value to limit the number of subfields (can
be usefull if you just want to keep the first element of the list, or to keep
the number of subfields to a reasonable number, as some features from your
GML file have a big number of elements in the list)
Even
Le Monday 12 July 2010 20:04:00 Even Rouault, vous avez écrit :
> Jez,
> Yes this is a limitation of the shapefile format (and most drivers,
> PostgreSQL databases being one of the exceptions).
> Try adding -fieldTypeToString IntegerList,RealList,StringList to your
> ogr2ogr command line. This will transform any field of those types into a
> String field by concatenating the values into a single string (what you can
> see with ogrinfo). Beware that if the list if longer more than a few items,
> there will be a truncation at 80 characters.
> I'm considering to see if it's practical or not to add an option to ogr2ogr
> to split fields of type *List into several fields of simple type.
> Best regards,
> Even
> PS: For the record, in http://download.osgeo.org/gdal/daily/, you can find
> daily snapshots of the source code of the trunk (1.8.0dev) and the 1.7
> stable branch.
> Le Monday 12 July 2010 18:09:16 Jez Walters, vous avez écrit :
> > Even,
> > I've just rebuilt GDAL/OGR using the latest code from the GDAL 'trunk',
> > but now I get the following error using ogr2ogr to convert an OS
> > MasterMap chunk (e.g.
> > http://www.ordnancesurvey.co.uk/oswebsite/products/innovations/sampledata
> >/O SMasterMap_Topo/58116-SX9192-2c1.gz) into ESRI shapefiles:
> > "ERROR 6: Can't create fields of type StringList on shapefile layers."
> > The various fields for which this error is reported do not appear to be
> > in the resultant shapefiles. Unfortunately this makes the new GDAL code
> > unusable for me.  :-(
> > Any thoughts?
> > Jez
> > -----Original Message-----
> > From: Even Rouault [mailto:even.rouault at mines-paris.org]
> > Sent: Sunday 11 July 2010 11:12
> > To: gdal-dev at lists.osgeo.org
> > Cc: Martin Daly; Peter J Halls; Jez Walters
> > Subject: Re: [gdal-dev] ogr2ogr problem converting UK Ordnance Survey
> > MasterMap
> > Just to inform you that now that the NAS driver is in GDAL trunk, I've
> > been able to port its enhancements to the main GML driver. On the few
> > samples I've tested, OS Mastermap GML files seem to be read correctly
> > now.
> > See http://trac.osgeo.org/gdal/ticket/3680
> > Le Friday 02 July 2010 09:04:38 Martin Daly, vous avez écrit :
> > > >     Here it is not only GDAL/OGR that has a problem!  Currently, I
> > > > know of no importer that can handle this construct, other than the
> > > > tool (from Snowflake) used by OSGB to generate it - and there is also
> > > > the question of onwards storage.
> > > Not even close, I'm afraid.
> > > There are plenty of tools to read (all parts of) OS MM:
> > > http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/informat
> > >io n/ technical/software.html
> > > e.g. (an excellent one, at a very reasonable price...)
> > >io n/ technical/software/cadcorp.html
> > > Also, as far as I am aware, OS GB use in-house software to generate the
> > > data.
> > > Martin
> > >** ** * This email is confidential and may be privileged and should not
> > > be used, read or copied by anyone who is not the  original intended
> > > recipient. If you have received this email in error  please inform the
> > > sender and delete it from your mailbox or any other storage mechanism.
> > > Unless specifically stated, nothing in this email constitutes an offer
> > > by Cadcorp and Cadcorp does not warrant that any information contained
> > > in this email is accurate. Cadcorp cannot accept liability for any
> > > statements made which are clearly the sender's own and not expressly
> > > made on behalf of Cadcorp or one of its agents. Please rely on your own
> > > virus check. No responsibility is taken by Cadcorp for any damage
> > > arising out of any bug or virus infection.
> > > _______________________________________________
> > > gdal-dev mailing list
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > The information transmitted is intended only for the person
> > or entity to which it is addressed and may contain
> > confidential and/or privileged material. If you are not the
> > addressee, any disclosure, reproduction, copying,
> > distribution, or other dissemination or use of this
> > communication is strictly prohibited. If you have received
> > this transmission in error please notify the sender
> > immediately and then delete this email.
> > Any representations or commitments expressed in this email
> > are subject to contract.
> > This message has been scanned for viruses and dangerous
> > content. However, it is essential that the recipient also
> > checks this message using commercially available mail
> > scanning and anti-virus software. IPL Information Processing
> > Limited accepts no liability for any loss or damage resulting
> > from any virus or other dangerous content in this message.
> > IPL Information Processing Limited is registered in England
> > and Wales under company registration number 1418818.
> > Registration took place at Cardiff on 10 May 1979. IPL
> > Information Processing Limited's registered office and
> > normal place of business is Eveleigh House, Grove Street,
> > Bath, BA1 5LR, United Kingdom. IPL is also registered for
> > Value Added Tax (VAT) under registration number GB 601 2931 83.
