[gdal-dev] MEM Datasets
James Meyer jamesm at lantic.net
Tue Jul 13 09:59:58 EDT 2010
Ah yes that's it.
Thanks a lot!
On 7/13/2010 2:33 PM, Frank Warmerdam wrote:
> James Meyer wrote:
>> Hi
>> Actually I did call it.
>> Sorry I just didn't include it in the code because it was much
>> earlier in the program.
>> However after some playing around, it seems that the error only
>> occurs IF I did a write to the MEM dataset. (Although it occurs WHEN
>> I close it).
>> The code I am using to test is below line-for-line exact. I basically
>> read from an existing dataset (known to be GDT_Byte) into the
>> in-memory dataset.
>> It seems like some sort of buffer overflow, because if I delete the
>> last two lines (that frees the buffers) I get a long "stack smash
>> detected" printout in stead of a segmenation fault.
>> Can you see anything I am doing wrong?
>>>      void* data = malloc(datasize);
>>>      sprintf(filename,
>>>        "MEM:::DATAPOINTER=%p,PIXELS=%d,LINES=%d,BANDS=%d,DATATYPE=%s",
>>> &data, 100, 100, 1, GDALGetDataTypeName(GDT_Byte));
> James,
> In the sprintf() you should be passing "data" instead of "&data".
> Currently
> you are passing the pointer to the pointer "data" on the stack which
> is only
> 4-8 bytes long and that is being used, and written past, blowing the
> stack.
> Best regards,
