[gdal-dev] GDAL2Tiles
Guillaume Sueur no-reply at neogeo-online.net
Wed Jul 14 12:59:35 EDT 2010
That can last a bit. It depends on your geo extent and how many base
tiles will be generated. Gdal2tiles outputs a 10...20... counter, which
should help you calculate the global time.
Regards
Guillaume
Le 14/07/2010 16:33, Tejas Gajera a écrit :
> Hi,
> I have a Tiff image of around 30GB, and I want to create tiles using
> GDAL2Tiles command line utility. If anyone have used GDAL2Tiles command
> utility, please let me know how long it takes to generate all tiles?
> I have started tilling process two days ago and its still running (under
> process). I have no idea how long it going to take.
> Please throw anything you know about GDAL2Tiles.
> Thanks in advance.
> Best,
> Tejas Gajera
