[gdal-dev] gdal compilation problem
ahmet temiz ahmettemiz88 at gmail.com
Fri Jul 16 02:01:51 EDT 2010
hello
and thank you Tamas,
I am using linux ubuntu.
I tried to use gdal-1.7.2.
regards
2010/7/15 Tamas Szekeres <szekerest at gmail.com>:
> 2010/7/15 ahmet temiz <ahmettemiz88 at gmail.com>
>> hello
>> I urgently need to have gdal-java.
> If you work on Windows, you can obtain complete packages from
> http://vbkto.dyndns.org/sdk/
>> But an error arose at compilation in swig-java like this
>> gdal_wrap.cpp:4381: error: ‘sProgressInfo’ was not declared in this scope
> It seems to be working for me. Which version did you try to compile?
> Best regards,
> Tamas
