[gdal-dev] Enhance attribute index support with OGR SQL queries (shapefile and mapinfo format)
Tamas Szekeres szekerest at gmail.com
Fri Jul 16 08:47:01 EDT 2010
2010/7/16 Frank Warmerdam <warmerdam at pobox.com>
> Tamas Szekeres wrote:
>> Folks,
>> I've added 2 tickes with working patches to implement reasonable additions
>> to the current (fairly limited) attribute index support.
>> Support attribute index scan with the sql 'IN' operator: ticket 3686 <
>> http://trac.osgeo.org/gdal/ticket/3686>
>> Add attribute index support for the sql queries in mapinfo tab format:
>> ticket 3687 <http://trac.osgeo.org/gdal/ticket/3687>
>> I would largely be interested in applying those changes in trunk or
>> probably in the stable branch (considering this as a performance bug fix
>> rather than an enhancement).
>> Any further ideas/comments would be helpful.
> Tamas,
> By all means go ahead in trunk.
> Applying the change in the stable branch should be done very cautiously
> (IMHO).
Will do so, thanks.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100716/be105e30/attachment.html
