[gdal-dev] building GDAL + OCI on linux
Pasta Bolognese pasta.bolognese at gmail.com
Fri Jul 16 19:44:01 EDT 2010
thanks for that...
Is there anywhere from where I can download the OCI headers and
Libraries needed to compile GDAL ? I don't have Oracle for Linux (I do
have it for Windows) and buying it just for compile GDAL would not
make sense...
On Fri, Jul 16, 2010 at 9:40 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> Here you can download OCI and Geor plugins for GDAL 1.7.2 compatible with OSGeo4W:
> http://download.osgeo.org/gdal/win32/1.7/
> To build GDAL witn support for OCI and GeoRaster in Linux you need ORACLE_HOME environment variable and --with-oci=yes
> The OTN page that I sent previously has more info.
>>  -------Original Message-------
>>  From: Pasta Bolognese <pasta.bolognese at gmail.com>
>>  To: gdal-dev at lists.osgeo.org
>>  Subject: [gdal-dev] building GDAL + OCI on linux
>>  Sent: Jul 16 '10 11:37
>>  Hi All,
>>  as OSGeo4W doesn't have the GDAL17 GeoRaster and the 1.6 has some
>>  bugs... I'm trying to build it on a Linux Virtual Box...
>>  The first question is, HOW ???
>>  I do have Oracle, but I dont't have the Linux version (only Windows).
>>  Where can I find all what I need to build GDAL + OCI (GeoRaster)... ?
>>  thanks
>>  _______________________________________________
>>  gdal-dev mailing list
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
