[gdal-dev] Yll corner wrong when i am reading ASCII file using
    Frank Warmerdam
    warmerdam at pobox.com
    Fri Jul 23 10:28:13 EDT 2010
mail2vajram wrote:
> Here i am using C# library for GDal, when i reading the YllCorner value using
> GeoTranform method i got that Yll corner value wrong.
> Eg:  yllcorner 1648000  ..........>original
>        yllcorner 1747000 ...........>Gdal
> Why, this much difference i got......
mail2vajram,
You don't show how you are trying to get the yllcorner from
GetGeoTransform().  I will note that the origin provided in the
geotransform is the top left, not lower left corner.
You might also need to provide the file header for further comment.
I don't know if the difference is a top-to-bottom distance, or just
half a pixel - in which case it is related to the center vs. corner
of pixel origin issue.
Best regardes,
