[gdal-dev] gdal2tiles.py cannot find EPSG:900913, sees only GDAL 1.6.1
Jean-Claude REPETTO jrepetto at free.fr
Wed Jul 28 09:10:24 EDT 2010
Le 28/07/2010 14:05, Jeffrey Warren a écrit :
> I'm getting this error when running gdal2tiles.py with even default
> parameters, on files which run fine on another separate machine:
> ERROR 6: EPSG PCS/GCS code 900913 not found in EPSG support files.  Is
> this a valid EPSG coordinate system?
No, the correct code for Google Maps is EPSG:3857.
<http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::3857&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=EPSG:3857>
Jean-Claude
