[gdal-dev] gdal2tiles.py cannot find EPSG:900913, sees only GDAL 1.6.1
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Wed Jul 28 09:21:45 EDT 2010
On Jul 28, 2010, at 9:10 AM, ext Jean-Claude REPETTO wrote:
> Le 28/07/2010 14:05, Jeffrey Warren a écrit :
>> I'm getting this error when running gdal2tiles.py with even default
>> parameters, on files which run fine on another separate machine:
>> ERROR 6: EPSG PCS/GCS code 900913 not found in EPSG support files.  Is
>> this a valid EPSG coordinate system?
> No, the correct code for Google Maps is EPSG:3857.
900913 is a common alias, and one that I believe is
supported by GDAL. EPSG:3857 didn't exist when 1.6.1
was released, afaik, so it definitely wouldn't be supported.
(Standards don't necessarily match reality.)
> <http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::3857&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=EPSG:3857>
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
