[gdal-dev] RFC 29: OGR Set Desired Fields
Thu Jul 29 13:07:47 EDT 2010
Tamas Szekeres wrote:
> Martin,
> I didn't follow all conclusions made earlier in this thread, but I don't
> think it makes much sense to enable/disable the special fields since
> those are derived from the attributes of the feature instead of fetching
> the values physically from the data source. For example OGR_STYLE
> corresponds to OGRFeature::GetStyleString() which can provide a
> meaningful value even if the styles are not handled/supported by a
> particular driver.
Tamas,
Geometry is generally derived from the physical data source, and knowing
that it can be ommitted can save substantial io and processing.  I must
confess this is less obvious with regard to styles.  I can *imagine*
styles being expensive to collect and form in some cases but I can't
think of any existing driver collecting the style string is particularly
expensive.
Best regards,
