[gdal-dev] Clearing OGR Attribute Filter on ESRI Personal Geodatabase
Joel Odom joelodom at gmail.com
Fri Jul 30 09:57:29 EDT 2010
What's the process by which I can submit that change, or request to have
someone with commit access add it?  Thanks.
On Fri, Jul 30, 2010 at 9:54 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Joel Odom wrote:
>> I'm encountering an issue where once I've set an attribute filter on an
>> ESRI personal geodatabase, I cannot clear that filter.  If I pass NULL to
>> SetAttributeFilter, the filter is internally set to "", which makes future
>> queries return zero results instead of all rows.  Examining the personal
>> geodatabase driver code, I find:
>> OGRErr OGRPGeoTableLayer::SetAttributeFilter( const char *pszQuery )
>>    if( (pszQuery == NULL && this->pszQuery == NULL)
>>        || (pszQuery != NULL && this->pszQuery != NULL             &&
>> EQUAL(pszQuery,this->pszQuery)) )
>>        return OGRERR_NONE;
>>    CPLFree( this->pszQuery );
>>    this->pszQuery = CPLStrdup( pszQuery );
>>    ClearStatement();
>>    return OGRERR_NONE;
>> Around the line, "this->pszQuery = CPLStrdup( pszQuery );" should there be
>> an additional bit of logic that sets this->pszQuery to NULL if pszQuery is
>> NULL?  I've searched this mailing list and find no reference to this.  Is
>> there a possible work around?  Thanks.
> Joel,
> Yes, I think you are right.  I imagine this:
> should be replaced with:
>    if( pszQuery )
>        this->pszQuery = CPLStrdup(pszQuery);
>    else
>        this->pszQuery = NULL;
> Could you file a ticket on this issue at http://trac.osgeo.org/gdal?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
http://www.operationliberate.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100730/a34bd5c4/attachment-0001.html
