[gdal-dev] Re: Warning 6: Driver GTiff does not support D creation option ....
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Jun 1 11:53:23 EDT 2010
Jan Tappenbeck <tappenbeck <at> widemann.de> writes:
> HI !
> i try to merge two image with the following command:
> gdal_merge -v -o D:\CAD\Schulungen\GDAL\XXXX\test.tif -of GTIFF -co
> --optfile D:\CAD\Schulungen\GDAL\XXXX\filelist.txt
> but there only will be one image convert into a ~250 gb file with this
> message:
Try without -co or give some valid creation option like TFW=YES.
-Jukka Rahkonen-
