[gdal-dev] GeoJSON2SHP and SHP2GeoJSON Java library
Tue Jun 1 16:05:47 EDT 2010
Lopes, Jose wrote:
> Hi,
> I am searching for a pure Java library to convert GeoJSON objects into
> ESRI Shapefiles and vice-versa, preferably open source…
> Up to the moment I found only ogr2ogr with Java binding and the ArcGIS tools to do this task.
> But I think somebody out there should have made this before with a pure Java library that can be used independently of any other COTS or exe, like a jar file…
> Does anybody know of any project like that?
Jose,
I would suggest looking at GeoTools.  It has at least good shapefile code.
It may also have GeoJSON support.  If not, you might have to implement that
part yourself.
Good luck,
