[gdal-dev] Pretty Much Off Topic: Development IDEs
christian.mueller at nvoe.at christian.mueller at nvoe.at
Tue Jun 1 23:21:32 EDT 2010
Hi, I am also a fan of working in the command line. (vi is one of my friends)
I use eclipse which is very powerful. Most of the time I am doing
Java, but I also used eclipse for programming python and there is
support for C++/C too.
Java / python really makes your life easier. The only reason for
working with C is performance for image operations, but most of them
are already there and bindings for higher level languages are supported.
I also use ubuntu 10.04, so try a
apt-cache search eclipse
to see what is already there.
Quoting Zoltan Szecsei <zoltans at geograph.co.za>:
> Cross posted with gdal-dev and ossim-developer
> Hi Everyone,
> Please indulge me in this slightly off topic question.
> As I have spent the last many years of my GIS life programming in a
> (linux BASH-like) scripting language, I am somewhat out of date with
> Linux development environments.
> I last programmed many years back, in C using Visual Studio 95 and
> "flat C" on Linux command line - no fancy "make" or anything.
> I want to migrate my Linux based GIS workflows onto OpenSource
> projects, using a mix of gdal/proj4/ossim and maybe GRASS - as the need
> and mood grabs me.
> I have just loaded Ubuntu 10.04 64 bit as my platform, and ask if
> anyone is willing to let me know what development environments they
> program in.
> I'm looking to write graphical (over orthos/satelite images) digitising
> routines, ie: display/edit/capture vectors on/in image windows, catch
> mouse, keyboard and maybe joystick events. Maybe even stereo (3D)
> capture too.
> I am not a fan of GUI data capture, so whilst this looks much like
> reinventing the wheel, I don't think it is, and hence I am unlikely to
> see the benefit of  "tacking onto" projects like QGIS etc.
> I'd be grateful to know what you guys use for programming. (I'll
> probably stick with C as I have no experience with Java, Python or
> other languages).
> Thanks in advance,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> P.O. Box 7, Muizenberg 7950, South Africa.
> 65 Main Road, Muizenberg 7945
> Western Cape, South Africa.  34° 6'16.35"S 18°28'5.62"E Tel:
> +27-21-7884897  Mobile: +27-83-6004028
> Fax: +27-86-6115323     www.geograph.co.za
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
