[gdal-dev] satellite photo height data
=?gbk?B?uMrL4KGjy7zUtg==?= weixj2003ld at 163.com
Wed Jun 2 05:40:41 EDT 2010
The file contains the satellite photo height  data one area,in my case,it contains the areas of two case.
在2010-06-02 17:33:10,"Chaitanya kumar CH" <chaitanya.ch at gmail.com> 写道:
Which file is that?
2010/6/2 甘肃。思远 <weixj2003ld at 163.com>
Thk u for your answer.
Maybe I have not descript my question clearly.
I can not get the file(which is dem file?) of the the satellite photo height  in the following areas:
1. Latitude :   44.750373989-----44.879927098
    Longitude: 86.797943335------86.932148806
2.
Latitude   41d38'34''N ------41d50'12''N
Longitude 81d29'35''E------81d37'38''E
some one tell me some web address,but I do not know how to download it(my English is not good),could you download it for me and send it to me by e-mail.
thk u.
weixj2003ld,
First you have to locate the corner pixels corresponding to the lat/longs you indicated. Go through (http://www.gdal.org/ogr/osr_tutorial.html) to do that. Use "WGS84" system for lat/longs.
Use GDALRasterIO() (http://www.gdal.org/gdal_tutorial.html) to retrieve the pixels from the required area.
I want to get(download) the satellite photo height  data(maybe .img or dem,I think) of the two following areas,who help me?
2.
Thank u in advances.
网易为中小企业免费提供企业邮箱(自主域名)
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100602/8e64dbaa/attachment.html
