[gdal-dev] OGR/SQLite : SELECT GEOMETRY failes on layer copy
Anders Moe anders.moe at geocap.no
Fri Jun 4 04:08:32 EDT 2010
Hi everyone
I'm using OGR with the SQLite driver, calling
OGR::DataSource::ExecuteSQL ()
By examining the sqlite file I've discovered that the geometry column is
named , well, GEOMETRY.
So I do something like
SELECT name, GEOMETRY as G from world
which gives me a resulting layer with these two columns. But when copying
that layer using
OGRDataSource::CopyLayer  ( )
I'm getting
In GetNextRawFeature(): sqlite3_step() : not an error
I guess that the geometry BLOB column is not recognized as geometry during
the copy, maybe.
So : Does anyone know how to do these kinds of SQL operations that preserve
the geometry column in a way that can be used in subsequent operations, like
layer copying ?
 Also, the OGRAPI does not seem to support any notion of geometry column
name. Anyone know a way around this ?
Cheers,
Anders
________________________________________________________
Anders Moe
Technical Manager
Geocap
w: +47 22 95 56 66
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100604/3e657913/attachment.html
