[gdal-dev] OGR/SQLite : SELECT GEOMETRY failes on layer copy
Even Rouault even.rouault at mines-paris.org
Fri Jun 4 17:43:08 EDT 2010
Anders,
2 things :
* There was a bug specific to the fact that you copy from a SQL result layer
(by opposition with a table layer). Fixed by
http://trac.osgeo.org/gdal/ticket/3617
* You also need to remove the "as G" from your SQL request. Otherwise the
SQLite driver will not be able to recognize the BLOB column as a geometry one
(it would write the data, but not add the info in the geometry_column table).
The OGR API can return the geometry column name (if available). The call is
OGRLayer::GetGeometryColumn()
Best regards,
Even
Le Friday 04 June 2010 10:08:32 Anders Moe, vous avez écrit :
> Hi everyone
> I'm using OGR with the SQLite driver, calling
> OGR::DataSource::ExecuteSQL ()
> By examining the sqlite file I've discovered that the geometry column is
> named , well, GEOMETRY.
> So I do something like
> SELECT name, GEOMETRY as G from world
> which gives me a resulting layer with these two columns. But when copying
> that layer using
> OGRDataSource::CopyLayer  ( )
> I'm getting
> In GetNextRawFeature(): sqlite3_step() : not an error
> I guess that the geometry BLOB column is not recognized as geometry during
> the copy, maybe.
> So : Does anyone know how to do these kinds of SQL operations that preserve
> the geometry column in a way that can be used in subsequent operations,
> like layer copying ?
>  Also, the OGRAPI does not seem to support any notion of geometry column
> name. Anyone know a way around this ?
> Cheers,
> Anders
