[gdal-dev] S57 questions
ogr user mrxonx at hotmail.com
Fri Jun 4 20:57:19 EDT 2010
Frank,
 I submitted an improved patch (it adds a method to OGRPolygon and will
work a lot faster for polygon assembly, no need to copy all those
rings). If that's not acceptable - it may be possible to simply collect
rings in an array and build a polygon that way. Would you mind taking a
look?
ogr user wrote:
> Done, http://trac.osgeo.org/gdal/ticket/3610
> Frank Warmerdam wrote:
>> Mike,
>> This would indeed be a useful change. I'd encourage you to file it in
>> Trac
>> and I'll look at incorporating it.
>> Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
